PD;
I just need to caution you, that even if you do get a response, there's no guarantee that someone's "Bermuda Isle" finish -- as done in California will be the same as your "Bermuda Isle" done in Alabama
I can tell you that the pools with the bluest, clearest looking water have white gunite. Most people don't realize that very clear, very clean water IS blue, very blue. Colored pools tend to look somewhat muddy by comparison.
I can also tell you that colored pool finishes add significantly to water temperature, anywhere from 2 -10 degrees. And in S. Alabama, it's not hard to warm a pool in April with a heat pump or solar heater, but it's very hard to cool one down in July, when the water hits 92 degrees!
