FC remains 0/0, use bleach?
I have been stuck with trying to get an above the ground pool (20x12x48) acceptable for swimming. There is a ton of information out there from various sources some of which I find contradictory and argumentative. I've been patient but confusion reigns on getting things squared away when even some professionals have entirely different approaches.
Currently I have the following HTH products to work with: 6-way test strips, 3-1 chlorinating skimmer tablets, super shock, algae guard 3xconcentrate. I assume being in Texas with the real hot weather starting I will also need stablizer(CYA) added. Despite attempts to get things ideal the test strips for FC remain 0/0 and the water remains cloudy with TH,pH,TA on the low side but acceptable. I guess the basic questions I have are how to correct this and are the use of bleach and baking soda good to use for getting balance? I am sure this has been asked before but it seems there is always some kind of variable that makes my problem unique. I appreciate any help at this time.
