Results 1 to 10 of 22
Thread: Help interpreting FAS-DPD FC/CC test results **Sorry, long, techy post**
    BigDave's Avatar
    Default Re: Help interpreting FAS-DPD FC/CC test results **Sorry, long, techy post**
    JJB,
    Did you read my post, just beore PD's? Do you think that answers or helps lead to an answer to your long post from last night? I interpret your long post to be asking( in a very detailed way) "Why does my FAS-DPD testing work differently than it seems it should?"
    -- OOPS -- so you did.
    Take it easy, see if you can clear up the CC in a bucket, then you'll know you can clear your pool.
    Do you have a pool cover that is dark or opaque? If so, uncover your pool at least part of the day to let sunlight on it as that can help bring down the CC.
    I don't know why the FAS-DPD chlorine test isn't giving you clear readings. Though sometimes the water gets a little cloudy during the test, the color transition is usually pretty clean. See this link and click on "Pool/Spa" on the left, select the K-2006 "To Test (Free and Combined Chlorine) using FAS-DPD".
    By any chance was your pool converted from a different type of sanitation such as Baquacil/biguanide/PHMB? There may be something in your pool causing interference with the FAS-DPD test.
  1. Newbie needs advice interpreting first test results
    By laughingboy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2010, 10:30 PM
  2. Test results post fiasco
    By kathgilliam in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-26-2006, 12:54 AM
  3. Test kits - interpreting the numbers
    By kbcpa in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-10-2006, 08:45 AM
  4. How long to get Borax PH increase test results?
    By famdog in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2006, 01:50 PM
  5. ps234 test results - first post
    By charlie75 in forum DPD-FAS based testing
    Last Post: 05-31-2006, 09:11 PM
