I'll have to remember that one!
OK.
1. Turn off the ozone generator; it just complicates things. If you can get money back do so, but turn it off regardless.
2. See if you can get the HTH 6-way kit at your Walmart (check availability)
3. If not, get a cheap OTO/phenol red test kit. You'll still need the K2006 (see the test kit info page in my sig), but the regular suppliers are currently out.
4. Lower your pH to near 7.0, using muriatic acid (guide page linked in my sig). Keep it in the 7.0 - 7.2 range.
5. Use PLAIN 6% household bleach to maintain chlorine levels in the OTO yellow to medium yellow range.
6. Remove tabs and ALL chemicals from your skimmer, feeders (if any) and system. Then, use the skimmer to add bleach, 1/2 gallon ONLY at a time.
7. Do NOT add anything to increase alkalinity.
8. DO get your pool store to check your calcium level, and tell us what it is.
9. I'm going to have to wait awhile for the stuff in your pool to break down, before we can use other stain chemicals. Otherwise, we could get into an unpleasant mix.
10. Consider using CuLator:1 ppm Culator, direct from AmazonWe don't know that they work . . . but we think they do, and IF they do, they'll remove any metals that are STILL in your water.
1.5 ppm Culator, sold by Amazon, shipped from Periodic
4 ppm Culator, sold by Amazon, shipped from Periodic
If you get them, get this, too:Poolmaster 16242 Poolmaster Skimmer Basket Linerand put the CuLator UNDER the sock -- that way, you'll be able to use it till it's saturated with metals, rather than having it get plugged with pool goo.
11. See if you can get some polyquat locally (info here)
If not, you can get it here:Kem-Tek 311-6 Pool and Spa 60-Percent Concentrated Algaecide, 1 QuartYou need to keep your chlorine low, to avoid further staining; the polyquat will help prevent algae for now.
12. Do a white bucket test for metals in your fill water -- we need to figure out how the metals are getting into your pool:+ Get a WHITE clean 5 gallon plastic bucket.THEN
+ Add 4 gallons of whatever water you fill your pool with
+ Add 1/4 cup of plain 6% bleach and 1/8 cup of baking soda. Mix and cover.
+ After 24 hrs, inspect for sediment. Note quantity and color. Recover
+ After 24 more hours, inspect again. Let us know what you find.+ repeat the process with your POOL water.
. . . that's enough for now.
