Results 1 to 10 of 27
Thread: green water
    Default Re: green water
    I'd do a half a box of borax at a time. After a couple of hours, retest and redose until you get it where you want it. Probably between 7.4-7.6 although anywhere between 7.2-7.8 is ok.
    Regarding alk, it is going to take quite a bit of baking soda (like probably 15 or 16 lbs.) but you certainly don't want to put in that much at once. You can actually buy a big bag of baking soda at Walmart and also at Sam's Club, I think. I'd probably do a couple lbs. at a time. Take a few days to get it all in there. You add Borax and baking soda slowly through the skimmer while the pump is running. It is ok to add a dose of one right after the other with no problem.
    mrszaff is offline Registered+ Thread Analyst mrszaff 0
    May 2010
    New York
    thank you I will keep you posted!!!
    16x32' rectangle 19K gal IG vinyl pool; bbb; jacuzzi sand filter; jacuzzi pump; 8hrs; Taylor 2000; utility water; summer: none; winter: vinyl / water bags; ; PF:6.3
    May 2010
    New York
    thanks watermom... I was away for the weekend when I read your posts so last night i got back after being away for 2 days, the pool looks like a swamp, can't see bottom.I feared that it would take a truckload of bleach so I added 2 lbs of Leslie's Power Powder Plus its a chlorinated shock,(active ingredient is 65-70% Calcium Hypochlorite) and borax and baking soda
    my numbers are now(after 24 hours) ...
    fc 22
    cc 0
    ph 7.2
    alk 100
    Pool is still green and cant see bottom but it looks a bit lighter green.
    should i stick with powder or switch to bleach? filter has been on nonstp for days, tried vacuuming and backwashing too
    shoulld i shut it off overnight?
    Remind me so I don't have to hunt through this long thread, what is your calcium hardness reading and CYA reading?
    May 2010
    New York
    cya is 80 , calcium 50
    I just did it now
    Go ahead and use the cal-hypo since your CH reading is low.
    May 2010
    New York
    how much more can i put in? I have added 3 ils total in 24 hours so far and still green
    they are in 1lb bags
  1. light green water due to metal in my well water
    By marios in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-17-2013, 08:48 PM
  2. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  3. green water or green liner?
    By denanbob in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 12:16 PM
  4. green water that won't go away
    By kinneydd in forum Dealing with Algae & Slime
    Last Post: 06-30-2006, 09:40 PM
