Results 1 to 10 of 22
Thread: FC and TC Too High and won't come down
    May 2012
    Default Re: FC and TC Too High and won't come down
    Couldn't get to the pool store that does water testing. I bought a Basic 5 Test Kit. The 1st Chlorine reading at 2-3 seconds was a 5.0. After 2 minutes, it was > 5.0 (it looked a bit darker (more orange) than the sample guide color.) The pH was 7.6. It said to add an extra drop of #4 when doing the pH and Alk tests, so I did. The Alk took 17-18 drops to turn clear/light yellow (so it's 170-180 when it should be 120-150). So while my pH is good, my Alk is too high and my Chlorine levels are still out the roof. My pool is 9 years old, 18x36 Grecian shape with a swim out and built in covered steps. It gets at least 8 hours of full sun. All of the equipment is Haywood and it's a sand filter. I also have a pre-plumbed Polaris 360 and pump.
    What should I do next? Drain more water out and add fresh?
    25K IG vinyl pool; PF:4.5
    I'm not sure how you are interpreting your chlorine as being "out the roof" with those results. Try this. Use the dilution method described in this link to see if you can get a little closer with your chlorine reading. This dilution method is not super accurate, but better than nothing. It does not replace having a good test kit, however. You will still need a Taylor K-2006 kit.
    Testing Without a Good Kit
    We still need a CYA reading. That is one of the critical test results to help us help you.
    Do not drain more at this point and do not worry about the alk at this point.
    May 2012
    OK, I'll try that. Is there a CYA test I can buy locally? I won't be able to get the K-2006 until next week. Is it safe to swim in the pool? I'll report the results with the diluted test shortly.
    Edit by Watermom to merge two posts in the queue:
    Results of diluted test: Chlorine looks to be 6.0. I did the diluted test at equal parts x2 and 2/1 x 3 and came up with 6.0 both times. Whew, it's not as high as I had thought. The pH was 7.4 (between 7.2 and 7.6) and the TA was 170. After reading some older posts about CYA being realy high, made me think that mine probably is, but I won't know until the pool store opens Monday or I get my K-2006 next week. My reason for thinking the stabalizer was too high is because upon opening the pool it tested low (nude color on the strip) and I was to add 7.5# of increaser which I did. Now it's a magenta/maroon color, which on the stick is "very high" I'll just leave the pool alone until next week when I can get the CYA tested. I had already taken out the chlorine tablets from the skimmer basket so it's not getting any more chlorine. Thanks for all of your help. Sorry I've been panicky.
    Glad to help. If you have a K-2006 ordered, don't buy an additional kit. Just let a reliable pool store test your CYA Monday and report it. Don't let them talk you into buying a bunch of stuff! Then, when your kit arrives, you can test it yourself.
    We are glad to help you!
    May 2012
    I took water samples to 2 different stores:
    First store used a Taylor kit and showed TC 4.0, FC 4.0, pH 7.6, CYA 70, TA 119. She also said there was a little bit of copper but not enought to worry about. She said pool was great and don't need to do anything.
    Second store sells BioGuard and uses BioLab testing: TC 9.5, FC 6.9, pH 7.1, CYA 121, adjusted TA 71, TA 107, Tot Hardness 60, Saturation Index -1.2. They said I needed to add Alk up, pH up, Calc Hardness up, Oxysheen to eliminate combined chlorine.
    (I used my test strip just to see what it showed and it's still showing > 5.0 TC and > 10.0 FC.) My drops kit is showing 6.0 with the diluted test.
    My Taylor k-2006 should be here by the end of the week.
    What do I need to do? Also, if I want to change to the BBB method, do I have to do it all at once or can I use up the Shock and chlorine tablets I just opened and add in the other B's as I need them or as I run out of what I have. Where is the best place on the forum to learn about the process of using the BBB so I can educate myself on what I will be doing. Thanks!
    The BBB Method is not primarily about using bleach, borax OR baking soda -- those just happened to be the pool chemicals that were available in the grocery store when I started PoolSolutions. The BBB Method is about using chlorine to manage your pool in the cheapest, most efficient and most effective way possible. SOMETIMES bleach is a part of that, OFTEN borax is a part of that. Baking soda is, too -- if you need it, and you do NOT!
    Your test results are amusing (Taylor / BioLab)
    FC: 4.0; 6.9
    TC: 4.0; 9.5
    pH: 7.6; 7.1
    TA: 119; 107
    CH: -; 60
    CYA 70; 121
    You don't need: Alk up, pH up, Calc Hardness up, Oxysheen. You might need a box of borax, but it can wait till you get a kit.
    You SHOULD continue to use what you have to maintain chlorine levels -- do NOT let your chlorine get low.
    Tell us the EXACT brand and product names of what you have, and we can tell you what the best option for using them is.
    May 2012
    I posted my chemicals, but haven't seen it on the thread and was wondering before i open the $80 tub of chlorine tabs if i should take them back and use bleach and how much or just keep them and use them up. Thanks!
  1. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 04:47 PM
  2. High amounts of DPD Powder needed!! To high or no Clorine?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-16-2012, 10:52 PM
  3. High Phosphates > 1,000 & High Nitrates 90ppm
    By applepar in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2011, 04:49 PM
  4. had algae, PH high, TA high, water now cloudy
    By Mom4fun in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-12-2011, 12:09 PM
