Thread: Nirvana heat pump?
    Default Re: Nirvana heat pump?
    Log out first and then search and then you should be able to see the results.
    I upgraded your membership . . . and Googled "Nirvana heat pumps".
    Not sure I'd want a Canadian heat pump with no US distributor -- service could be a really pain!
  1. which heat pump would be best? what should I look for?
    By alisonquilts in forum Pool Equipment & Operations
    Last Post: 08-23-2012, 07:28 PM
  2. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 08:37 PM
  3. What heat pump NOT to buy?
    By marcs in forum Pool Equipment & Operations
    Last Post: 01-28-2007, 04:18 AM
  4. Heat Pump
    By mohawk in forum Pool Equipment & Operations
    Last Post: 09-04-2006, 12:08 AM
  5. Exactly what is a heat pump?
    By JETTA in forum Pool Equipment & Operations
    Last Post: 06-26-2006, 01:32 AM
