Thread: DIY bottom repair questions
    May 2012
    Delaware
    Default DIY bottom repair questions
    OK....so I have a liner pool 18x36, 8 foot deep end...pretty standard. Long story short it is at this moment it is a wrech. Loner is in tatters and the bottom has been affected by rain, plants, and the like. I have called around with much dismay (and outrageous prices) for a company to do the replacement, and at this point I am looking to do it myself. The liner does not seem to be the big issue, but the bottom repair may be. It is sand in the shallow end and appears to be a sand/concrete mix down to the deep end. It is very rough and in the edges there are areas where it has washed out below the wall line. Should I do a skim-coat in vermiculite over the whole thing? Just smooth the sand? I will post photos if I get approved. Also any recomendation on liner companies? I have come across many with proces ranging from $795-$1400. (the mil does vary). I am trying to do this as economically as possible, but not something I want to have to redo in a couple years. I also have a well pipe (for the groundwater) any suggestions how to best handle that? Much thanks in advance
    Stephanie
  1. Can't get bottom flat, can pool bottom be slightly concave/bowl shaped?
    By SkierDude in forum Intex-type Pool Setup & Operations
    Last Post: 06-30-2013, 12:13 PM
  2. popup repair
    By phil469 in forum In-Ground Pool Construction and Repair
    Last Post: 10-31-2011, 11:28 AM
  3. New Pool Owner Questions - 8 questions!! :)
    By kmmlangston in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2010, 05:33 PM
  4. Pool light repair questions.
    By BillF99 in forum Pool Equipment & Operations
    Last Post: 06-10-2007, 12:40 PM
