I have decided to try to add some DE to my sand filter. I have followed the recommendations in another thread by premixing a little bit of DE at a time and waiting approx. 20 minutes for a pressure increase. I've added about 1/4 cup each time, but no pressure increase. I've noticed though that the water became cloudy. I then did a little experiment by adding another 1/4 cup and I can see actually see the return becoming cloudy right after adding the DE, i.e. the DE (or perhaps most of it) goes right through. My filter and sand is only 3 weeks old. The sand is the correct type and amount (aquaquartz 0.45-0.55mm, 100lbs). I run my filter mostly at 15GPM and sometimes at 27GPM, the S166T has a "design flow rate" of 35GPM, so I don't suspect any channeling could have developed. From what I've read, sand filters should filter around 20-100um particles and according to wikipedia, DE is typically 10-200um, so a sand filter should filter most of the particles. Am I missing something here ? Any help would be greatly appreciated.
Thanks,
N.
14' 1500gal intex AG
hayward S166T filter
hayward max-flow 1.16HP 15/27GPM
120sq ft solar panels
