I know there have been some problems with the liqudator clogging because of a buildup of 'white stuff' on the float valve and in the tubing so it is not a maintenance free solution. I do know that an online retailer of the liquidator (and test kits based on Taylor reagents) stopped selling it a few years back because of some type of problem but I am not sure of the details. I have never used one but when it works it seems to be an inexpensive, if not perfect or trouble free, way to automate bleach addition to a pool.
As far as having to add acid all the time, the main cause of pH rise in a pool is from outgassing of CO2. The use of the liquidator will not change this. A SWCG might actually increase the aeration and outgassing of CO2 and cause faster pH rise. If your pH is rising too fast you might want to try lowering your TA if it is high (above 80 ppm) and you might want to consider adding 50 ppm borate to add a secondary pH buffer system.
