Results 1 to 10 of 24
Thread: Another cloudy water thread...can't seem to fix it
    Apr 2012
    United States
    Default Re: Another cloudy water thread...can't seem to fix it
    TheGoose - I noticed that...I had shut it off for a few minutes and when I turned it back on the pressure went down but after 15 minutes or so it was back up again. I've since backwashed and this time only added 2-3 cups of DE. Next time I'll add slowly and wait until pressure stabilizes before adding more to get the right amount (thanks Watermom).
    I read another ongoing thread in this forum and I feel like I'm suffering from the same issues as others this season due to, what I think may be, an oversized pump. I'm running a 1.5 HP Hayward Superpump through a Hayward S244S sand filter and, after checking with my pool installer, found out that my pump is at the upper limits of the filter specs. Last year the water was crystal clear all season long. Now that I had a seriously green pool to start and really need to filter the dead bacteria out of the water it may be pushing too hard to filter as effectively as I need it to. Although, the DE project seems to have helped some. I can now see the bottom of my shallow end...We're at least seeing some progress. I'll keep at the DE 'thing' until it clears up. I'll probably be due for another backwash by the end of the day as the pressure continues to rise (obviously a good sign!).
    Thanks,
    JP
    22500gal IG 22x36 lagoon w vinyl liner -- 1.0HP 2 speed Hayward Superpump -- Intermatic P1353ME digital pump control / timer -- Hayward S244S sand filter -- New Water W400 in-line Auto Chlorinator -- Polaris 9400 robotic pool cleaner
    Jun 2011
    In the Sticks near Houston, TX
    My old pump was a 1.5 HP with an old Sta-Rite Swimquip DE Filter. When I switched I decided to go back with a 1-HP and a sand filter. I figured that since the filter was rated for ~60 gpm I was in good shape but now I'm finding out that I'm really at the upper level of flow for that filter and I have never really had consistent results. I'm strongly considering either going back to DE or up one size on my sand filter.
    ~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
    Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
  1. How Do I Kill White Molds and Pink Slime?
    By smullins34 in forum Dealing with Algae & Slime
    Last Post: 06-15-2012, 01:52 PM
  2. cloudy water
    By dave198 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-21-2011, 10:56 AM
  3. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
  4. cloudy water
    By Dennis Fritzsche in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-13-2006, 08:28 PM
