Results 1 to 10 of 36
Thread: Chlorine level is low
    May 2012
    South Carolina
    Default Re: Chlorine level is low
    Well I guess I have to get another test kit. The kit I have from Leslies is "Basic Poolcare DPD Test Kit" Free Chlorine or Bromine,pH and I ordered the k-1515 today so now my question is what other kits am I gonna need before I can do anything else?
    Quote Originally Posted by sherriemoseley View Post
    Here's the Leslie's page: http://www.lesliespool.com/Home/Pool...Test-Kits.html
    Tell me exactly which kit you have (none there are called "Basic Poolcare DPD").
    May 2012
    South Carolina
    18571
    DPD Basic Test Kit
    Arrg-g-gh. NOT one of my favorite Taylor kits (Taylor # K1001); the Taylor K1000 (OTO) is much more useful. I do NOT like DPD color match kits, for all sorts of reasons. But for a variety of reasons, the pool industry LOVES them. At least, the pH test in that kit is good.
    OK. Standard recipe again:
    1. Get an OTO kit locally, (see the test kit info page link in my signature) but continue to use the pH test from the Taylor K1001
    2. Get 2 gallons of plain 6% bleach (can probably get bleach and kit at Walmart).
    3. First evening after you have both, test the pool, add 1 gallon of bleach, test the pool again (record the color -- orange? even if it doesn't match)
    4. Following AM, test the pool again, and again that evening. Let us know what you see.
    5. Order a K2006 (same test kit info page)
    6. Tell us what sort of pool you have (vinyl, FG, concrete) and the make / model of both your pump and filter
    7. Give us a list of the chemicals you've put in since opening. We'll need exact brand names, since terms like "shock" or "chlorinator" have no particular meaning.
    May 2012
    South Carolina
    Okay I have continued to add a gallon of bleach every evening and I just received my k-1515 kit today. I just ordered the k2006 so in the meantime can I use the kits I have? Also I'm a little confused on the k1515 because it says: For 1 drop=0.2 ppm,use 25 mL sample or For 1 drop=0.5 ppm,use 10 mL sample.So which one do I need to use 10 mL or 25 mL? I am off work tomorrow and would like to do your recommendation tonight and tomorrow AM. I already posted my pool info on this thread 5-4-12. As far as the list of chemicals I've put in since opening, I reeally cant give you the names of any of it because I used it all as instructed by Leisure Depot and no longer have the containers. I know we did pH increaser and a flocculant and I had to vacuum algae to waste,then Calcium Plus which I still have some left and the brand name is Sparco and lots of shock which I think the brand name was Pool Life, maybe?
    Use the 10ml sample line. That way, you add the DPD, then count the drops of FAS solution till it turns clear. (Swirl after each drop!) Multiply the drop count x 0.5 and that's your ppm reading.
    Post your test results, once you have them.
    If you'll make a signature line with all the pool info, it makes it easier for us to help. That way, we don't have to keep scrolling back up through a thread to find it. You can use the link in my signature below to help you do it.
    May 2012
    South Carolina
    Ok I think I did the signature line right. Thanks! Just tested pool then added 1 gallon bleach and retested. Will test again tomorrow morning and evening and post all readings then.
    18' round 7.7K gal AG vinyl pool; Bleach; Hayward S144T sand filter; Hayward 1HP pump; hrs; Taylor K-2006; City; summer: ; winter: ; ; PF:16
  1. Unable to keep chlorine level and CYA level has dropped from 38 to 21 in 1 day.
    By lizbyrne2000 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2013, 12:41 PM
  2. CYA level and chlorine level and pool store recomendation
    By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 11:25 AM
  3. chlorine level ?
    By LazyLgrecian in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-09-2007, 08:57 PM
  4. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
