The only way to get this pool cleared up is to consistently keep chlorine in it. You may also have some filter issues since you think some of the DE came out. I'll let Ben address those. But, even if you have to have filter work done, you'll still need to keep chlorine in there or else you aren't going to have a cloudy pool, you'll have a green pool!
You can either use bleach for your chlorine and then add some CYA separately. If you go this route, you'll need about 5 or 6 lbs. of CYA, often called stabilizer or conditioner. The ingredient will be cyanuric or isocyanuric acid.
OR you can chlorinate with dichlor for awhile which will add chlorine and CYA at the same time. You can buy it at a good price at Sam's --- PoolBrand. Some other places are selling blends which have unwanted stuff in there, so be careful what you buy. (Once your CYA level gets to 40-50, you'll want to switch to an unstabilized form of chlorine, though.)
No guarantees about Saturday or Sunday though..........
