Thanks Ben.
After re-reading my post, I guess I should have specified that I don't follow the SWCG manufacturer's recommendation on FC levels (1-3) since in the past it has just resulted in algae problems; not visible algae, but a slick liner, which I imagine would have turned into visible algae had I not addressed it quickly. Even with FC levels at 7-8, I was still having problems (important to note that at that time I was not using borates or Polyquat 60).
Your explanation seems to mirror one thing I've learned since having a pool (this is the only pool I've ever owned; installed in 2004), that what works for one pool may not work for another. I suspect that at least part of the reason is that the environment around the pool is likely different for every pool.
Thanks to sites like this and a particular pool store manager that was genuinely interested in helping me and not just selling me a bunch of chemicals, I've learned quite a bit over the years and continue to do so.
After a steep learning curve, I settled on a routine that has worked for me for the past several seasons. It pretty much includes the following:
FC at 5 (as mentioned, controlled using an Aquarite SWCG)
TA 80-100 (I use bicarb to raise when it gets low)
PH 7.5-7.8 (I add muriatic acid once it hits 7.8; PH has never been too low, so I've never had to add anything to raise it)
Borates 40-50
CYA 70-80
In terms of regular maintenance, besides testing and adjusting the above as needed, each week I add a maintenance dose (8oz) of Polyquat 60 and a maintenance dose of Jack's Magic Purple Stuff (12oz; I use to have problems with staining before using this. I was told the staining was a side effect of the SWCG. Since using it, I've not had any staining problems.). I shock every 2 weeks (or after a big storm) using calcium hypochlorite (68%). Also, I run the automatic vacuum frequently to keep the pool clean (every couple days on average).
I'm not sure if I'm overdoing things and wasting money by using both Poly60 and borates. I started using them at about the same time (I was fed up with the liner frequently getting slick with aglae so decided to hit it with both guns!) so I'm not sure if just using one would give me the same algae control.
I would appreciate your input on my routine and if you have any suggestions that may save me time and money.
Thanks again.
