Thread: humming no circulation
    Apr 2012
    kentucky
    Default humming no circulation
    Help! I am going ibnto my 3rd year of pool ownership and already have had a quarter size hole in my liner and a pretty bad alggae bloom. At the end of last season after I backwashed, I went back out and my pool was humming with no circulation. I unplugged and left it until the next day and when I plugged it back it started running. Again, a few days later, same story. I remember reading last summer that something was sticking in the open/closed position inside but I can't remember what it was or how to fix it. Help!!!! It's a Hayward.
    Default Re: humming no circulation
    If you can tell us the make and model on both your pump and filter, we'll be able to tell you more.
    Meanwhile, if you will mix plain 6% household bleach with water (1:2) and pour it around your pool, you can keep your pool from getting slimed while you work this out. Add 1 gallon of 6% bleach per 10K gallons of pool water to start (3 gallons if it's already turning green) .
  1. Adding CL with no circulation? Help!
    By JimK in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-03-2013, 11:59 PM
  2. Pool pump making humming noise then shuts off
    By Campbell in forum Pool Equipment & Operations
    Last Post: 10-30-2012, 11:36 PM
  3. Another humming pump...........
    By aylad in forum Pool Equipment & Operations
    Last Post: 01-16-2012, 04:44 PM
  4. Sta-rite pool pump humming.
    By MikeyG in forum Pool Equipment & Operations
    Last Post: 07-24-2011, 11:07 AM
  5. Hayward 1 1/2 Super Pump humming noise
    By Madty in forum Pool Equipment & Operations
    Last Post: 08-02-2006, 12:28 AM
