Results 1 to 4 of 4
Thread: Draining Filter
    Apr 2012
    Carolinas
    Default Draining Filter
    I can not get to the drain for my filter due to all the pipes surrounding it. It has a very slow leak. Should I just put up with the leak? Also, when washing the Filter grids (DE filter), is it too big of a problem not to drain the filter completely?
    Default Re: Draining Filter
    How slow is "slow"? A gallon a day? A gallon a minute? Is the pool noticeably losing water? Is there a mess around the filter? Those would be my decision points.
    Apr 2012
    Carolinas
    Less than a gallon a day, probably closer to a gallon a week. It's,enough to keep it wet around the base of the filter, but definitely no noticeable drop in pool levels.
    Speaking just for my messy, sloppy self . . . I wouldn't re-pipe a pump pad for a 1 gallon per day leak.
    (In point of fact, I haven't. The kiddie pool TR-140 filter at ___________ Golf and Country Club has had a crack around the top threads that's been leaking about that badly (1 - 2 gallon/day) for 5+ years. I'm finally going to see if I can fix it.)
  1. Water draining from Spa when filter pump turned on...
    By Strawfoot in forum Pool Equipment & Operations
    Last Post: 07-20-2008, 04:28 PM
  2. Water draining from my Filter when pump is off
    By mphare in forum Pool Equipment & Operations
    Last Post: 01-03-2008, 08:19 PM
  3. water draining from filter
    By poolbee in forum Pool Equipment & Operations
    Last Post: 05-23-2007, 02:19 PM
  4. Draining with a cartridge filter
    By csevel in forum Pool Equipment & Operations
    Last Post: 07-23-2006, 01:29 AM
  5. Cleaning pump filter w/o water draining out.
    By les_smith in forum Above-Ground Pool Construction & Repair
    Last Post: 06-22-2006, 10:51 PM
