Hi,
I am looking to replace my pool pump. My in-ground pool is 15-20k gallons and is one of those "play" pools where it's shallow at both ends for playing volleyball or some other type of water sport. It also has an attached spa with a waterfall that empties into the pool. I currently have an ancient-looking Hayward pump with an even older-looking motor called "The Californian" attached to it. (The motor has a sticker on it with a bunch of information that is legible in case I need to provide more info.) It's a 2HP motor and the name A.O. Smith is on the green info label. The pump is connected to a Hayward Pro Grid DE filter and the whole thing is run by an Intermatic model #T20001R1.
I'm looking to replace my pump in order to save $$$ on operating costs. In your opinion, what pump should I get that will work with what I currently have and will also save me money/pay for itself in the long run? (I saw your deleted posts about the ecopump and that made me laugh!)
Also, what should the labor cost normally run to remove the old pump, install the new pump, and modify the pipes?
Lastly, PoolDoc is AWESOME. PoolDoc is honest and to the point. Very refreshing!!!
