Results 1 to 8 of 8
Thread: buying house with salt water pool and a fafco solar system any advice?
    Apr 2012
    Chandler, AZ
    Default buying house with salt water pool and a fafco solar system any advice?
    Just new to this need info especially on solar system and pool service.
    roy
    Default Re: buying house with salt water pool and a fafco solar sysytem any advice?
    Hello dirtfrmr, and welcome to the forum!
    Do you have any specific questions? It's hard for us to give info if we're not sure exactly what you're looking for....
    Apr 2012
    Chandler, AZ
    they say it leaks on the roof, i assume it is the pipes detrioarating from the arizona sun. It is salt water pool just don't know about the care of the pool and the solar system. it was installed about3 years ago, warranty transfer, i am not sure if it is a money pit or not.
    How long should i think a fafco solar system last. It is 3 years old, in chandler az.
    Ft Lauderdale, Fl
    If it's under warranty still, I would contact the pool builder or the warranty center. It may be worth while to pay for a session with their service manager to get training on your system, so you know what you have. You can also post photos of your equipment set and all the fine experts here can give you further instructions. You can also review all the past information on this site, which is very useful for successfully taking care of your pool yourself.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    Apr 2012
    Chandler, AZ
    thanks will do when we close on the house in late may. My questions were with the solar system and the leaks and wondering if this was a common maintence issue? I assume that i will have to learn about salt water pool care as I have had experience with an above ground pool in Wisconsin which is a much different climate. Thanks for your response
    rh
  1. Considering Buying a house with an Indoor Pool...
    By EdWalleman in forum --cleanup--
    Last Post: 11-06-2012, 07:13 PM
  2. Buying a house with a pool; what should I ask?
    By veghead in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-13-2012, 01:55 AM
  3. Buying new filter system, need advice
    By Halfdone in forum Pool Equipment & Operations
    Last Post: 07-16-2011, 11:45 AM
  4. Buying a house with a pool--need advice
    By jmac31 in forum In-Ground Pool Construction and Repair
    Last Post: 06-01-2011, 07:02 PM
  5. Buying A House With A Concrete Pool, No Expansion Joints Around Coping - Need advice
    By grakk in forum In-Ground Pool Construction and Repair
    Last Post: 04-19-2011, 12:33 PM
