Thread: Advice Needed for AutoClear Cell from 2008
    Default Re: Advice Needed for AutoClear Cell from 2008
    Quote Originally Posted by Cuuhl View Post
    How do I determine if the flow switch and/or the cell itself needs to be replaced?
    I'm not familiar with your unit, but it sounds like you need to see if Hayward can help you. Sean is the AutoPilot guy, not the Hayward guy. I don't know how to find a manual for that unit, but they should.
    Still, it sounds like you may need to replace everything UNLESS you have the skills for DIY wiring and plumbing testing and modifications.
    Ft Lauderdale, Fl
    Ben, the Autoclear is a Polaris system...Hayward will not help, as they were bought out by Zodiac. I only recommended a flow switch similar to the AutoPilot or Hayward style because the AutoClear cell has the flow switch integral to the cell. The AutoClear flow switch is similar in design and is a basic normally opened/normally closed type switch, which can be tested with a multimeter. Usually if this is the problem, your power supply will show a code or warning light specifically for a flow condition.
    If the cell is dead, then replacing it should get you back in operation.
    Google search for AutoClear Chlorine Generator showed cells still available on line. Not sure if this is accurate or not.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    Apr 2012
    Arkansas
    Thanks for the advice! I'm may see if I can find a replacement cell online. Or, I may just say the heck with it and go to chemicals. Probably cheaper and easier in the long run.
  1. SWG not making chlorine--new cell needed?
    By ccrimmin in forum --cleanup--
    Last Post: 06-08-2013, 11:40 AM
  2. Help needed in replumbing a new AquaPure style 3 port cell into old 2 port cell space
    By Anonymous European in the US in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 11-27-2012, 01:06 PM
  3. Check_In and Advice Needed
    By Orkalovesfood in forum DPD-FAS based testing
    Last Post: 06-08-2007, 11:22 AM
  4. Replacing liner; Advice needed!
    By JenniferB in forum In-Ground Pool Construction and Repair
    Last Post: 01-10-2007, 06:38 PM
  5. Decking Advice Needed
    By Bearbacker in forum In-Ground Pool Construction and Repair
    Last Post: 06-15-2006, 04:25 PM
