Thanks for the suggestions. The pump does require a "B" cartridge and I purchased a 6 pack. With the prior pump (which used a "A/C" cartridge, I rinsed them after use (which sometimes was everyday!) and would put them in a bucket with water and shock for about 30 minutes. Had to be careful I didn't forget to remove them though because the shock would eat through the plastic on the (cheap) filters. I will definitely try the bleach and detergent!
Still looking for a solution to the skimmer basket connection, which will also be my vacuum connection. Can't set up the vacuum with the way everything is installed now, because the only hoses are on the outside of the pool and go directly to the pump. Inside the pool consists of the strainer that directs water to be filtered and the blower which forces the clean water into the pool. Not sure where I'd connect the vacuum. I hope this is making sense. The 1500 gph pump connections that I just replaced had threads on the strainer piece (inside the pool) that would accept a connection that ran to the skimmer basket or you could remove the skimmer and attach the vacuum.
Thanks!
Karen
