Results 1 to 10 of 11
Thread: Getting serious about water testing finally
    Apr 2012
    Northern NJ
    Smile Getting serious about water testing finally
    First off, thank you all for your incredible advice on this forum and the pool solutions site.
    I became a first-time pool owner when I moved to NJ and purchased a house with an above-ground 18x30. My wife and I have two young boys and decided we'd keep the pool for a year and see if we used it/liked it. Needless to say, we love it, but I'm still a newbie. Last year I had to swap out the pump since the bearings froze up (twice). I have a Hayward 1.5hp with a sand filter. Since I inherited the pool with the house, I have no idea what condition the sand is in.
    Everything worked ok last year, with some random water fogging and algae blooms. For the most part I'm using chlorine tabs in a addition to the BBB method. I've only used test strips, but my K2006 is on order (sorry, didn't see the Amazon link until after I ordered it!).
    I'll let you know some readings when I open the pool soon, but thanks for the tips so far!
    Apr 2012
    Northern NJ
    Default Re: Getting serious about water testing finally
    So as I'm still learning and finding my way around, I have a quick question about chlorine stabilizer. I think my tabs have stabilizer in them, but I saw a 4lb bucket on sale for about $10 so I bought two. I'm trying to read more about it, but is this a chemical that I'll need a constant supply of? (the store has more-- should I get a bunch?) or is this more of a one-time add and it stays in the water?
    Still waiting on my K2006.
    above-ground 15'x30'x3.5' oval -- Hayward 1.5hp Power-flo matrix, Vari-Flo XL -- Swim Pro 3.2 sft sand filter, 250# of sand
    The tabs should be trichlor tabs, and they do have stabilizer in them. You need a certain amount of stabilizer (CYA) in the water to keep the sunlight from consuming all of your chlorine, but as your stabilizer level rises, so does your minimum chlorine level. Take a look at the link to the Best Guess chlorine chart in Pooldoc and Watermom's sigs, and it will outline where your chlorine needs to be in relation to your stabilizer level.
    Having tabs is a good thing for vacations, etc, or to raise your CYA to where you want it (we recommend 40-50 ppm for most pools), but it will be very difficult for you to use it as an exclusive chlorine source without algae outbreaks, especially toward the end of the season. Once the CYA is in the water, it is only reduced by splashout, backwashing, and very severe algae blooms, so once you get it where you want it, there should be very little adjustment throughout the swim season. Also, check and make sure your tabs don't contain copper--copper is what turns blonde hair and fingernails green, and can stain your pool liner.
    Apr 2012
    Northern NJ
    Thanks Janet. I'll check the tabs and their ingredients.
    I use tabs mostly because I'm not home for several days at a time, and my wife REALLY doesn't want to get into chemicals and maintenance other than the occasional skimming.
    Last year I used tabs (usually three at a time), and supplemented or "shocked" with bleach when I needed to. This was all before getting deep into the forum and only testing with strips, so this year will be a big learning curve. Funny you mentioned late-season algae blooms, because that's EXACTLY what happened. I assumed it was due to the fact that the pool got more late season sun (it was shaded by trees for overhead mid-summer sun, but got the slanted late-summer stuff).
    A different question on more of an equipment line:
    I have a Hayward 1.5 hp Power-flo matrix pump mated to a Hayward vari-flo XL valve (valve says 75 gpm max), on a swim pro sand filter (3.22 ft sq. effective filtration, filt. rate 25 gpm, 250lbs sand). Pump is basically new since the old one locked up and I just replaced it with the same specs. I remember finding out somewhere that my setup was most likely part of a kit. Pool is about an 18x30 oval 4' deep (give or take).
    I'm wondering how they're matched up since I keep reading about oversized pumps and undersized filters being a problem, and I'm wary that I'm suffering from one of the effects of the dirt being pushed through the filter. I remember vacuuming thoroughly last year and the next day finding all the dirt back on the bottom of the pool.
    Could this also be "bad" sand? Since I bought the pool with the house, I really don't have the history of it. Thanks all.
  1. What's the best water testing kit??
    By Pipecrew in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-17-2011, 09:51 AM
  2. testing tap water
    By sunofthebeach in forum General Interest
    Last Post: 08-25-2008, 03:18 AM
  3. Tale of my battles with cloudy water! I'm finally winning...
    By ladybug_3777 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-20-2006, 12:04 AM
  4. Testing my tap water pH
    By hulla in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-14-2006, 10:32 PM
  5. Testing well water
    By ChuckD in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-04-2006, 12:27 PM
