Results 1 to 9 of 9
Thread: Filter and Bleach
    Default Re: Filter and Bleach
    Looks like "Bac Pac" is just a high-priced trichlor cartridge used in conjunction with a Frog 'mineral' ( = copper) system.
    For now, you can use bleach. BUT, you need to know what your chlorine levels are AND what your stabilizer levels are. You can get a good idea on chlorine, even high levels, with an OTO kit. But the CYA pad on test strips isn't accurate enough to provide useful information . . . so you either need a K-2006 or a K-1721 CYA only kit. I'll paste links in tonight or in the morning -- I'm still working on them.
    By the way, you do NOT have to 'balance' your water in a vinyl above-ground. The only thing carbonate alkalinity does for you is help stabilize your pH. But, cyanurates and borates ALSO do that. Fix those first, and THEN, if you find your pH is unstable, you can worry about adding alkalinity. Otherwise, don't.
    AND . . . you don't need calcium at all. Period. Even a little. If you have it, it's not hurting anything, but it's not helping, either.
    1. Get rid of the algae, while
    2. Making sure your pH is between 7 and 8, then
    3. Decide on a sanitizer method: bleach, dichlor, trichlor, AND
    4. Adjust your CYA and borate level accordingly.
    5. Finally, do any other tweeking . . . IF it's needed.
    Here you go on the kit options. None of these are likely to be available locally, but you can buy them at various places online, besides Amazon which is were the links below go.
    Complete K-2006 kits; the 'C' model has 2oz bottles instead of 3/4 oz, so it has almost 3x the # of tests for 1.5x the cost.
    <-- K-2006 /===============/ K2006C -->
    You can use these to supplement your existing kit:
    <-- K-1515 FAS-DPD /==/ Taylor K-1721 CYA test -->
  1. Sand Filter and Cartridge Filter Owners Please Advise
    By amati5 in forum Pool Equipment & Operations
    Last Post: 08-30-2011, 06:05 PM
  2. Help! Switching out 1985 cart filter to sand filter
    By JLICHTY in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 11:09 AM
  3. Replies: 7
    Last Post: 05-16-2010, 09:46 AM
  4. Changing Sand in Filter and Random Filter Question
    By newbie2pools in forum Above-Ground Pool Construction & Repair
    Last Post: 07-24-2006, 03:38 PM
  5. Baq-to-Bleach conversion w/cart filter
    By Michael23 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-17-2006, 04:22 PM
