Re: Vacation pool
					Thanks, I do have a service and they come weekly.  Maybe I will try to convince her to start using BBB which may cut her cost as well.  Forgot about the CYA test limit being 100 max read, good point.  I will call the pool builder and get his advice on partial drain.
Would changing to salt be a possible alternative to high CL and high cya?  Think I read high CAL negativly impacts the CL generator.  Thanks for the advice
			NJ Pool:  In Ground, 40,000 Gal  vinyl liner, chlorinated using BBB, Gas Heated, DE Grid filtration.
FL Pool: 10K gal gunite, chlorinated with 3'' pucks, cartridge filter, spill over spa
