Results 1 to 10 of 22
Thread: Opening swampy pool, high PH
    Apr 2012
    South Carolina
    Default Re: Opening swampy pool, high PH
    Just an update... Been running the pump and filter 24/7 for three weeks. Switched over to bleach after getting my CYA to 40 using the dichlor. My chlorine levels hold at 10 for a day or two before they start to drop off and I have to add a gallon or so of bleach.
    The water is still really cloudy, to where I can can only see maybe a couple of feet down in the deep end. I see the bottom enough in the shallow end to make out large spots of dead algae that's settled to the bottom and I've been vacuuming this to waste as it accumulates.
    Is it normal to take this long to filter out all of the dead algae, or could there possibly be a problem with the filter? Would I need to consider changing the sand in the filter or maybe adding DE to it?
    18 x 36 in-ground vinyl pool / sand filter
    Three weeks is a long time to get it cleared up, but remember that it took a long, long time for the pool to get in the shape it was in, so it's going to be a long process to clean it up. If you're still seeing improvement in water clarity, then the filter is at least working. Do you see anything blowing back through the returns? One thing you can do is add the handfull of DE into the skimmer and then watch to see if it's coming back through the return--if so, then the filter has a problem. If not,then it's trapping the particles and you just need to apply another dose of POPP--Pool owner patience and persistence! YOu might also open the filter up and just make sure that it has an adequate amount of sand in it. Your owner's manual will tell you how full it should be, but I think with sand the general rule is about 2/3 full.
    Keep an eye on your pressure, and continue to backwash it when your pressure gets 8-10 psi over your "clean" pressure. I wouldn't backwash it any more often than that, because a dirty filter actually cleans better than a clean one.
    Quote Originally Posted by River Gronkowitz View Post
    I'm going with, "there's a problem with the filter".
    The two most common problems are (1) missing sand, blown out during backwash via oversize pool pump and (2) coarse non-filter sand, sold by pool stores trying increase their margin.
    If you post your pump and filter make/model, we can probably tell if it's likely you've blown out sand when you've been backwashing. This is more common on AG pools, but it happens on IG pools as well.
    But, either one of these problems will make clean up very slow. The DE test Janet described is also diagnostic: if you put DE in, and it blows back out, you DEFINITELY have filter problems.
    Apr 2012
    South Carolina
    The filter is a Hayward S-200
    The pump is a Hayward SP 1600-M and the motor model is UST 1102.
    Not quite enough info: the SP1600 is the general range for the Hayward SuperPump line up -- see which one you have on this page at Hayward.
    And, here the S200 series page.
    Apr 2012
    South Carolina
    Okay, got it now- it's a Hayward SP2607X10
  1. Opening with very high ph and mustard algae
    By greenwich3 in forum Dealing with Algae & Slime
    Last Post: 05-28-2012, 06:52 PM
  2. Spring opening cloudy pool excessively high PH > 8.2
    By JuJuBee in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-23-2012, 09:29 PM
  3. Swampy Cloudy Water...
    By Merrick in forum Dealing with Algae & Slime
    Last Post: 05-29-2010, 08:24 PM
  4. Help! Can't run pump, and don't want a green swampy mess!
    By Henrys514 in forum Dealing with Algae & Slime
    Last Post: 05-11-2007, 10:19 AM
  5. AG Vinyl stains from swampy water... need suggestions.
    By bimmerboy in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-16-2006, 11:26 AM
