Thread: Calcium deposits on tile
    Scottsdale, Arizona
    Default Re: Calcium deposits on tile
    Do you know how to acid test to distinguish calcium carbonate scale, from other scale?
    Do tell !
    Sorry, I was trying to figure out who "Dave66" was, what sort of pool he was working on, and what his skills were.
    Anyhow, anything "carbonate" is sort of 'solidified' carbon dioxide -- add acid, and it will fizz. Vinegar will work, but it's easier to see with muriatic acid -- of course, muriatic is harder to work with safely.
    But, if you can chip off a bit of scale, put it in a wine glass, and then cover it with white vinegar . . . you should be able to see it no problem. If you don't, add a bit more vinegar, cover the glass with Saran wrap (acetic acid is volatile) and let it sit overnight. If it doesn't fizz, bubble or dissolve . . . it's not "carbonate" based.
  1. Calcium deposits on pool tile above the water line
    By cliveleach in forum In-Ground Pool Construction and Repair
    Last Post: 08-02-2012, 08:47 AM
  2. Calcium Deposits?
    By Jasheon in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-29-2010, 09:39 AM
  3. Calcium deposits?
    By halefmly in forum Dealing with Alkalinity and Calcium
    Last Post: 11-11-2006, 11:26 PM
  4. Best way to remove Calcium Deposits
    By Allora in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2006, 03:49 PM
  5. Calcium Deposits?
    By GJBenn85 in forum Dealing with Alkalinity and Calcium
    Last Post: 05-22-2006, 09:21 PM
