Thread: No flow to booster pump
    Mar 2012
    Katy, Texas
    Default No flow to booster pump
    I've just replaced a burnt out booster pump motor and realized that there is no flow to the inlet on the booster. This is probably why the old pump burnt out. The main pump works fine and there is lots of flow at the waterfall and pool outlet nozzles. Any suggestions on how to trouble shoot the lack of water to the booster pump?
    -Mike
    May 2010
    Default Re: No flow to booster pump
    Hi Mike, welcome to the Forum. Can you give us more information, such as how big your system is, In-Ground or Above Ground etc. Maybe you can send photos to poolforum@gmail.com
    It's going to be pretty hard, without comprehensive photos of your piping.
    It could be a broken valve, a plugged or collapsed line, or simply a valve in the wrong position.
    BTG is right -- send photos.
  1. booster pump recommendation?
    By vinouspleasure in forum Pool Equipment & Operations
    Last Post: 05-14-2013, 11:24 AM
  2. booster pump problems
    By sunofthebeach in forum In-Ground Pool Construction and Repair
    Last Post: 05-15-2010, 02:55 PM
  3. Eliminate booster pump for cleaner with 2 speed pump?
    By breckens in forum Pool Equipment & Operations
    Last Post: 08-01-2007, 11:13 AM
  4. Add a booster Pump and run over Concrete?
    By Pam and Jim in forum Pool Cleaning: Manual or Automatic
    Last Post: 03-26-2007, 04:54 PM
  5. Too much booster pump
    By poolnewbie in forum Pool Cleaning: Manual or Automatic
    Last Post: 03-10-2007, 10:44 PM
