Hello!
I've got a 32x16 above ground oval shaped pool. Looking to create some type of run-off (using the cover) for the rain so it doesn't collect. Like a roof or teepee shape.
Long version:
I'm not going to open it again this year. In past years I've had the problem of rain collecting on the cover and sinking it down, having to pump it out, then the same thing happening again every time it rains. Even keeping it taught will only work for so long.
I end up with mosquitoes and other problems.
So, this year I'm looking to alleviate the problem all together.
I've heard the beach ball idea(setting an inflated beach ball under the cover), but I'm actually draining the pool completely. It's nearly drained now. I know this isn't good for the liner, but it's torn anyway and will need to be replaced before the pool can reopen.
So my thought is building two small platforms out of PVC and mounting them to each end of the pool. Then running some tough rope across one end to other. Each platform being around 1.5 ' above the pool. Then run two additional pieces of rope on each side (using 8" or so platforms) to each side of the main one for support.
Then run a new cover (buying a new one that is bigger [thinking 20x40]) over the rope, and screwing it into the deck to keep it taught. Creating a roof, or teepee shape for the water to run off of.
Am I crazy? Will this method work? Has anyone had experience with this problem before, or perhaps have a better idea?
Thanks so much!
