Thread: Recommended cleaning robots?
    Feb 2012
    Los Angeles
    Default Recommended cleaning robots?
    I just bought a new house and we are surrounded by trees that constantly blow leaves into our pool. I want to get a cleaning robot that will be plugged into electrical with the following criteria:
    - goes up wall and stairs
    - has a large capacity bag
    - has a well made bag so it doesn't easily fall apart and need to be replaced often
    - has easy access to take out the bag and throw it out
    - I am willing to spend around $1,000 though if I need to spend more I am open to it
    - has a remote control (only if it is something I should have)
    Can anyone recommend any models?
    Thanks!
    Jun 2011
    Louisiana
    Default Re: Recommended cleaning robots?
    Our pool is surrounded by oaks and is inundated by leaves and other dirt & debris
    we bought an aquabot turbo-t and abused it for 3 years before the pump motor started to wear out
    i have used a couple of other robots and the turbo-t delivered the goods
    way better leaf collection
    VASTLY superior fine particulate collection
    much better wall climbing
    BUT
    run your pump enough to allow the skimmers to collect the leaves
    thats the key ingredient
    dont waste your robots life doing what the skimmers will do
    thats my .02 :-)
    May 2010
    I can't recommend a robot, but I will suggest that you get an in-line leaf basket. My pool cleaner is vacuum operated, not electrical, and it will not climb anything, but the in-line leaf basket keeps tons of leaves out of the filter.
    May 2011
    Batesville, MS
    If you go the Polaris route, stay with the 280, the orifice is bigger and it is a little more economical in the beginning...
    18x36 IG Vinyl...Jacuzzi Pumpworks (the bane of my existance), VERY small pool biz - Full time Science and Math teacher!
  1. clarifer, recommended or not?
    By pbotz2000 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-19-2012, 09:56 AM
  2. Why is dichlor not recommended?
    By Farmingtonpool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 03-23-2012, 03:05 PM
  3. Are some robots better than others with gunite?
    By Enigma869 in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-17-2007, 11:30 AM
  4. Recommended resurfacers in AZ?
    By JasonA in forum In-Ground Pool Construction and Repair
    Last Post: 11-17-2006, 02:26 PM
  5. Robots vs. Manual
    By cheshamjim in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-14-2006, 01:08 PM
