Thread: Does anyone buy chem from wholesalers?
    pmeloy is offline Commercial pool users, operators, owners pmeloy Not to be trusted
    Nov 2011
    Surrey, BC, Canada
    Default Does anyone buy chem from wholesalers?
    I've been operating municiple public pools for about 18 years and one of the first things I leaned is to never buy chemicals from pool stores. I go to the local chemical wholesalers and purchase Bicarb/Calcium chloride in big bags. There is usually a minimum purchase amount ($250 where I went a couple years ago - still have lots left!). The only issue I had at first was caking due to storing in an unheated building but a cheapo plastic storage bin (with sealing top, not the kind with two halves that fold down) solved that problem. I keep unopened bags in the basement heated storage and the opened ones in storage bins.
    Caking of the bicarb wasn't a big deal as it breaks up easily enough. Caking of the calcium chloride is a royal pain in the bum.
    Default Re: Does anyone buy chem from wholesalers?
    Hi Pat;
    Probably 75% of the forum users have less than 12,000 gallons of water in their pool; for them, 1# of stabilizer is 10ppm. So, wholesale quantities usually don't make sense.
    Also, if you buy from the grocery store . . . or Sams Club . . . there may not be any advantage:
    + baking soda => from Sams: $0.30 for 12#; wholesale: $0.20 for 100#
    + cal chloride => RARELY needed, but available economically as ice melting salt.
    + bleach => wholesale quantities are perishable
    + dichlor => $2/lb at Sams for 50#; this is below wholesale in many areas
    + borax => ~$0.65/lb at Walmart; possibly 0.30/lb wholesale for 100#, but hard to find
    The three chemicals that are often much cheaper at wholesale -- cyanuric acid, polyquat & HEDP -- are not usable on home pools in wholesale quantities.
    So, while purchasing wholesale may work for a few, in select localities, it's not generally a practical option.
    Thanks for posting.
    Nov 2011
    Surrey, BC, Canada
    I wasn't clear. The $250 purchase was for my home pool, a 16x32 in ground.
    Fair enough.
    However, it's still true that buying multi-year quantities of chemicals doesn't work well for many pool users. We'd rather focus on saving money by using only the chemicals you need, rather than by buying bulk.
    I buy some chemicals in bulk because it is more economical for me (example, I buy 50 lb bags of calcium because my fill water is processed by reverse osmosis where I live so it is very soft) but other chemicals that I use infrequently (such as baking soda or stabilizer, which I need maybe once a year or less) I buy in small quantities. I do buy Muriatic acid by the 4 gal. case since it is cheaper and I have a SAFE place to store it. This is about a year's supply for me if not more).
  1. Chem log, to see....
    By Charlie_R in forum Pool Chemistry for Intex-type Pools
    Last Post: 09-05-2012, 10:16 PM
  2. Calling All Chem Geeks (incl. THE Chem Geek) re: storing pool chems
    By elsie in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-10-2011, 11:20 PM
  3. Which chem to increase ph?
    By kelemvor in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-16-2011, 06:14 PM
  4. Trying to keep up w/ Chem Geek
    By ShelleyAnn in forum Pool Equipment & Operations
    Last Post: 04-23-2007, 04:30 PM
  5. Help with water chem., and SWG
    By guild1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-28-2006, 02:39 PM
