Thread: Pool Pump
    Mar 2011
    San Diego, Ca.
    Default Pool Pump
    I installed a new Hayward pump and motor package last week and I cannot get it to hold prime. When i get it running it runs fine but the water bleeds down overnight. I've checked all the fittings and everything seams ok. The last pump and motor I replaced never had this problem, any suggestions? THANKS
    Default Re: Pool Pump
    The symptoms you describe point VERY strongly to a suction side leak, either in piping you replaced or piping you disturbed (moved, jiggled when you installed the new pump.
    Keep in mind that, when the pump is running a SUCTION side leak will allow air INto the pipes, rather than letting water leak OUT. Unless you can hear them hissing, suction leaks can be rather hard to find.
  1. Need new pump and was my old 1.5 HP pool pump too big?
    By deckview in forum Pool Equipment & Operations
    Last Post: 06-09-2012, 09:36 PM
  2. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 08:37 PM
