Thread: Pea gravel?
    Sep 2011
    Memphis, TN
    Default Pea gravel?
    Do you recommend using pea gravel in the bottom of sand filters? I have a Ranger RS24 (24" diamter) sand filter for a 27,000 gal. vinyl pool.
    Default Re: Pea gravel?
    *ONLY* if it is recommended by the mfg of YOUR filter. Dunno what a "Ranger RS24" is, so you'll need to look at the manual.
    With some laterals, pea gravel is needed. By the way, do NOT put either gravel OR sand in your filter without FIRST adding enough water to cover the laterals with 2+" of water.
  1. gravel in sand
    By mspool in forum Pool Equipment & Operations
    Last Post: 04-25-2011, 08:24 PM
  2. Yikes! Small pile of gravel in pool
    By NWMNMom in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2006, 07:26 PM
