I just realized something.
Carl (and I) think about A/B demand testing from the point of view of trying to teach newbies to use the test, adjust with small doses, test again method ("the TATA method"? ) . . . AND keeping the NUMBER of things tested and taught to a minimum. If a newbie follows the TATA approach, they'll never (or almost never) need the A/B test.
And in the process some of them get very frustrated since it takes so long and they go back to the pool store for their "miracle in a bottle"! Most pool owners, as you well know, do not have a lot of POP. If we have a tool at our disposal (since newbies are now getting the Taylor kit with the demand tests in them so they have them) to shorten the time why not instruct them to use the test when it is appropriate (such as the example I gave above in lowering TA, which is a common scenerio)?
Some of this comes from my background, controlling pH in commercial pools with acid feed, rather than slugged doses.
And this I more than appreciate since I also worked at a commercial facility with acid feed pumps that needed to be adjusted in very small increments. However, since we did test the water 3 times a day in each of the pools, hot tubs, and play areas we had a LOT of data for making the adjustments! Are we expecting the same from a home pool owner? I know I don't want to test MY pool three times a day or more to get the pH where I want it. If I have a 'ballpark amount" to get me very close that would be much better! I can then make whatever small adjustment (if any) is needed the next day.
FWIW, there are times when the TATA (test, adjust, test, adjust) approach is the only way such as with SWCGs when the owner is trying to adjust the cell output to maintain a specific FC level.
Evan, you have worked a lot with pool store walk-ins, where you are FORCED to use a large 'fire and forget' doses, because you have no idea if they'll come back. In THAT environment, A/B testing would be almost essential.
However, I was using Demand tests way before I did the pool store gig. I was the one who dug the demand tests out of storage so I could use them. No one else in the store knew what they were for. They just did the computer read out and handed it and the attached shopping list to the customer!
And of course, Richard instinctively approaches pool testing from the "how can I acquire the greatest possible amount of analytical information about my pool's water"? Obviously, A/B testing would be a component in that.
You seem to forget that I have a similar chemistry background to Richard and tend to do the same with my own pool. Then there is my many years worth of experience with reef aquarium keeping and water testing which is not that dissimilar to pool testing in many ways.
So I think what's happened here -- in part -- is we were all speaking from different perspectives, without noticing it. So, now I'm trying to 'notice it'.
I just think that blanket statements like 'demand tests are useless' are not beneficial (and I drank that koolaid when I was trying to help 'someone' promote their testkit business even though in private conversations I suggested including demand tests because they can be useful. However, this kit was being modeled (an exactly copy?) after another kit that had been available and this 'someone' wanted their kit to be the same. I agree that the demand tests can be considered "advanced" but we do have many users who "graduate' to that level quickly.
