Results 1 to 10 of 14
Thread: My First post - high salt?
    Jul 2011
    Boca Raton, FL
    Default Re: My First post - high salt?
    How are you measuring your salt levels?
    On my SWCG, I get different readings all the time. But over time, I take the lowest reading that pops up with consistency to be my "true" reading. Also, when I've taken water samples to the pool stores (samples taken at the same time and place from my pool), the pool stores give different readings for my salt level. So, I take their salt meter readings with... wait for it ... a grain of salt!
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
    Aug 2011
    Southeast Texas
    Quote Originally Posted by famousdavis View Post
    Grain of salt, pretty funny. I don't have inconsistent reading issues between the SWCG display, digital dip meter, and the pool store. Like PoolDoc said, these are all actually measuring salinity (and I knew as much, I was just sticking my head in the sand, trying to minimize any more testing/readings than I already do). The pool store reading will depend on the method of measurement.
    I've used the Aquachek salt test strips in the past and they're the most accurate I currently know of. So as soon as I receive the bottle I ordered online, that's how I will measure salt from now on, or until something better with reasonable effort and cost comes along.
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 09:43 AM
  2. First post, I have a high pressure reading 35psi
    By bri3180 in forum Pool Equipment & Operations
    Last Post: 10-03-2011, 06:57 PM
  3. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 04:58 PM
  4. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 12:56 PM
