Quote Originally Posted by sspine View Post
First, thank you for all the valuable information. Have been following this method for 5 years. Just installed new vinyl liner, filled with well water, used 5 gal bucket filled with batting. Have only added poly 60, brushing & filtering 24/7. Filtered loose rust out but stains wherever there are angles. Just tested with Taylor kit:
FC 0
PH 8
TA 330
CYA 0
Now I don't which to address first: start ascorbic acid treatment or lower ph & aerate to lower TA. Your advice would be greatly appreciated.
16x36 ig vinyl
Hayward 300# sand filter
1. Lower the pH ASAP to below 7.2 (not much below)
2. Hold it there -- it will rise on it's own, as your TA gasses off as CO2
3. Add a single dose of HEDP (Jacks Magic Pink, Purple or Blue Stuff is 100% HEDP -- if you can't find that, let me know.)
4. Buy some chlorine tabs, put them in the skimmer, and leave the pump on 24/7.
5. If you have a two speed pump or can throttle flow to 1/2 via a valve do so. Slowing the flow across the filter will help remove the iron.
(#4 & #5 will tend to drop the iron out ON the filter.)
- - - not finished, but gotta go. You can do those things listed now. Will add a list of HEDP sources later.
