You need to do a dilution, till you get in the range of the test method being used. For example, you can mix your pool water 50:50 with tap water (no CYA!), test, and then multiply the results by 2.
Once you know the actual CYA level, you can determine your correct chlorine level from the Best Guess chart. (link in signature box) .
Of course, you ALSO need to stop using whatever chlorine source is adding all the stabilizer, and switch to either cal hypo or plain bleach.
