Thread: Scale in a salt water pool (first post)
    Jul 2011
    Default Scale in a salt water pool (first post)
    This is a 25-year old 18k gallon pool, upgraded two years ago with a VERY dark Pebbletec finish and salt water system. We are getting a lot of scale on the Pebbletec, very noticeable because of the color. It will come off with an acid wash, but I would like to keep it off. Suggestions.
    Default Re: Scale in a salt water pool (first post)
    Sounds like you've got an excessive saturation index (calcium + alkalinity + pH too high)
    #1 - Order a K2006 test kit; you can use the Amazon link in my signature if you like. Do NOT get a K2005 by accident. It would be fine for this issue, but once you began trying to do your chlorine correctly, you'll need the K2006.
    #2 - Post full results, here once you get the kit.
    #3 - Meanwhile, get a cheap OTO / phenol red kit, and use it to adjust your pH till its around 7.0 (no lower!)
  1. First pool, water is clear but fiberglass is stained and lots of scale
    By MountainStone in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-15-2012, 11:14 PM
  2. My First post - high salt?
    By jonnymac in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-26-2011, 12:17 AM
  3. Salt water magic and Intex salt water/copper ionization system
    By enchantedmountain in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-10-2011, 05:37 PM
  4. post-winter scale on replastered pool
    By joeturf in forum In-Ground Pool Construction and Repair
    Last Post: 05-29-2006, 09:39 PM
  5. post winter scale on replastered pool
    By joeturf in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-23-2006, 08:54 PM
