Thread: Vinyl leak near stair flange
    Jul 2011
    Default Re: Vinyl leak near stair flange
    I have no way to take pictures under water..
    Welcome to the Forum!
    While I tried to present this to you last night on a different forum , apparently I was unclear
    You can try a patch. What you want to do is unscrew the faceplate in the affected area. Patch the holes below the faceplate but leave enough unglued patch to slide under the faceplate. Reinstall the screws, with the extra patch material between the faceplate and gasket, and you should be good to go.
    Start with the info here for patching a liner. (do this on the holes you can see)
    I guess I'm not explaining things correctly but, maybe someone here can put it in a different way that will make sense to you
    Jul 2011
    Thank-you Ted. I did understand. I am operating underwater and was reluctant to loosen the stair flange around the damage. I did place a large patch (1 1/2 in x 7 in) with one side up against the patch-to-flange interface. I then dabbed a liberal dose of marine sealant along that patch-to-flange joint and have slowed the leak considerably.. possibly stopped it. I view it as only a temporary solution until I can do a liner replacement, but hopefully it will last for a few weeks or a couple of months until I can have that done. We are in one of the parts of the country experiencing droughts right now and I wanted to be as responsible as possible on minimizing water use.
    Thanks for your suggestions.. sorry I didn't respond sooner.
  1. Hard to find part for stair trim - stair cap?
    By moblaine in forum Pool Equipment & Operations
    Last Post: 06-06-2013, 03:20 PM
  2. Vinyl stair repairs
    By austinM in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2013, 06:21 PM
  3. Stair, Vinyl Stain Removal
    By Cookieman in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-25-2012, 01:49 PM
  4. Help needed with vinyl leak
    By jkoch in forum Pool Equipment & Operations
    Last Post: 07-12-2010, 07:08 PM
  5. My Stair Dam Project or, Dam Stair
    By Poconos in forum In-Ground Pool Construction and Repair
    Last Post: 08-20-2007, 12:21 PM
