Thread: adding chlorine
    Jul 2011
    las vegas
    Cool adding chlorine
    A local "pool school" class I attended stated that liquid chlorine should be added to the pool at dusk or at night because it would quickly lose potency if added in direct sunlight. This is in Las Vegas where it is sunny almost every day. Any merit to this idea or more poor advice from pool shops??
    Default Re: adding chlorine
    Sunlight breaks down all forms of chlorine -- that's why you add stabilizer. But the effect is primarily on chlorine IN your pool, not on chlorine as you add it to your pool.
    We usually recommend that you add chlorine late in the day, especially when you are adding a large dose, in order to allow the chlorine to work all night before being affected by sunlight. But that recommendation isn't changed whether you add bleach, cal hypo or dichlor!
  1. Adding Chlorine Every Day
    By jhk49 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-16-2011, 11:07 PM
  2. 4 Questions about adding Chlorine
    By jenmenke in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-27-2010, 11:44 PM
  3. adding chlorine after closintg
    By vikes in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-16-2008, 07:39 PM
  4. Adding chlorine, how much is safe
    By Jeffski in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-11-2006, 08:23 PM
  5. Please help...adding CYA/chlorine question
    By Henrys514 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-09-2006, 12:40 PM
