Just a couple of quick notes:
#1 - Your pH reading is more likely to be correct when the chlorine is low, than when it is high.
#2 - Your best best for removing (more likely: lightening) rust stains on the deck is Iron Out, but do NOT put this in your pool.
#3 - Yellow (orangish!) stains that appear AFTER adding chlorine can be iron -- chlorine tends to precipitate iron. In your case, this may mean you've got more than 1 or 2 bits of iron or steel in the pool.
#4 - Vacuming to waste is the best way to get rid of sludge, so long as you don't P.O. your neighbor!
#5 - You may want to add some liquid metal control agent BEFORE you raise the pH. Otherwise, you may have a bunch of copper and iron stains.
