Results 1 to 10 of 10
Thread: Leak detection - 28K inground vinyl
    Default Re: Leak detection - 28K inground vinyl
    Welcome to the Forum!
    If you want to eliminate the plumbing, perform a vessel test. Turn off the pump, plug ALL inlets and outlets from the pool and mark the waterline in the pool. Concurrently, partially fill a bucket with water and mark the level and set it on a step. The next morning compare the water loss in the pool to the water loss in the bucket (any water loss in the bucket is due to evaporation). If the pool losses more than the bucket, you've got a leak in the vessel/ liner. If the loss is the same, it's a plumbing/ equipment leak.
    If you can do this test and report back, as to the results, we'll help you narrow down the source
    May 2011
    Hampton, NH
    Quote Originally Posted by waste View Post
    I'm familiar with the bucket test, but I'm not sure how I would accomplish plugging everything...
    Plugging the jets is easy of course, but I'm not sure of what an effective method would be for plugging the skimmer. For the main drain I'm truly baffled. How can one plug the main drain without scuba gear? Even then -- I wouldn't know what to put there that would actually create a reliable seal.
    Suggestions?
    You're right -- it takes SCUBA to plug the main drain . . . unless you are an accomplished 'free diver'.
    But, you can plug everything else. Then, your test become shell + drain, instead of just shell. Lowes probably has blow up Cherne plumbing test plugs available.
    http://www.cherneind.com/Pneumatic/Default.aspx
    SalemCastles Guest
    I plugged my main drain using a mask and snorkle and flippers. I'd dive down stay upside down and with flippers be able to stay there long enough to get a few turns on the screws holding the screen on. Once removed I gained access to the threaded port and it was the same size plug as the returns. It took me ten or fifteen dives with rests in between and I made sure I had a "buddy" keeping an eye on me. Having said that I would plug the holes in the skimmer first and wait to do the drain. The fact that yours slowed down tells me it isn't in the drain. My stairs have a few cracks and it was a previous repair that had started leaking again.
  1. How long does an inground vinyl liner last?
    By masspool in forum In-Ground Pool Construction and Repair
    Last Post: 09-13-2010, 03:48 PM
  2. Leak detection and repair - suggestions?
    By George in Georgia in forum In-Ground Pool Construction and Repair
    Last Post: 09-08-2010, 10:41 PM
  3. leak Detection dye?
    By offthefront in forum In-Ground Pool Construction and Repair
    Last Post: 08-28-2010, 07:53 PM
  4. My Ponder of the Day: leak detection invention
    By elsie in forum General Interest
    Last Post: 05-16-2007, 12:44 PM
  5. American Leak Detection came out....what do you think
    By AndieP in forum In-Ground Pool Construction and Repair
    Last Post: 07-26-2006, 10:26 PM
