The water level stabilized for 24+ hours at about 1" above the bottom of the skimmer intake, so I think I have the vertical location of the leak fairly well pegged.
My wife topped it off again though, so I'm not able to do a dye check with it right at the level of the leak at the moment. I'm assuming best chance of success is if I can put the drops on the surface of the water when the leak is very close to the surface as well.
I gave it another whirl anyway, checking all seams, corners, and around the skimmer by putting drops every inch or so. No luck, despite being a dead calm day and being able to do this while outside the pool. I'll try again when the level sinks some more. Won't take long! :-)
Am I being overly optimistic to assume that if the water level stopped above the jets and above the bottom of the skimmer intake -- and given that the pump is holding its prime -- that this rules out the plumbing as a source for the leak?
