Thread: swithing from cal hypo to bleach????
    mississippi
    Default swithing from cal hypo to bleach????
    how long do you have to wait to start using bleach if you have just sanitized with cal hypo? days or just until your chlorine level goes down. nervous about the switch but am trusting the info. on this site.any other info. greatly appreciated
    duraleigh Guest
    Default Re: swithing from cal hypo to bleach????
    Hi, MS,
    That's an easy one.......0 seconds!!!
    Your pool will never know you switched except for the fact it won't be getting any more calcium. I assume that's your purpose.
    Oh yeah, you'll get some funny looks at the grocery store, too.
    Jun 2012
    NJ
    How much and what bleach would be used in a 28,000 gallon pool?
    20'x40' rectangle 28K gal AG vinyl pool; Skimmer tabs; Pentair FSN+ 48 DE filter; Hayward 1.5hp pump; hrs; ; well; summer: none; winter: mesh; ; PF:4.3
    For a pool with a PF of 4.3 (yours!), 1 gallon of 8.25% bleach (typical Walmart concentration, currently), containing about 0.6 lbs of chlorine gas equivalent, would add 4.3 x 0.6 ppm free chlorine to your pool . . . or 2.6 ppm FC.
    Bleach initially raises the pH a bit, but after the chlorine is consumed, the pH drops back to the original value.
  1. difference between cal hypo and sodium hypo (from bleach)
    By kasatpoolforum in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-20-2010, 08:12 PM
  2. Bleach vs. Cal Hypo
    By CabanaMan in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-31-2006, 12:08 PM
  3. Switched from Cal Hypo to Bleach
    By Jakebear in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-26-2006, 06:45 PM
  4. Bleach vs Cal Hypo.
    By houston in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-24-2006, 08:38 AM
  5. cal hypo and bleach together?
    By scarywoody in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-25-2006, 03:16 PM
