I am in the process of converting to the BBB and, as recommended here, have been diligently checking and adjusting my chemicals daily. I dropped into a local (and new) pool store yesterday on a whim to check it out and get a water test just to confirm my testing. I did my own test using my Taylor kit just before I left and went in with the following numbers:
FC 4
TC 4
CC 0
pH 7.5
Alk 80
(CYA was 30 a few weeks ago so I expected to be somewhere in the 40s)
Pool store #1 ran my water sample in some fancy tester and reported the following:
FC 3.6
TC 3.6
CC 0
pH 7.9
Alk 90
CYA 55
Phosphates 500
I returned home and again ran my pH on my current and an older Taylor kit and again both showed the same, about 7.5 (very reddish orange, no hint of purple)
Concerned with the validity of the pH results, I took another water sample to Leslie's and they did a drop test and reported the following:
Pool Store #2
FC 3
TC 3
pH 7.6
TA 80
CYA 40
Phosphates 100
I'm confused on whom to believe and how to proceed. I noted to the first pool store that my pH result was widely different and they said that my Taylor kit was shot because I left it in the shed over the winter. Second pool store said that this shouldn't have mattered. It appears that my backup kit confirmed my initial test results which were also also confirmed by Pool Store #2's drop kit.
So, I guess my question here is whether variations like this can be expected between stores and, if so, is one type of store test a better barometer than the other? Like I said, Pool Store #1 used some fancy looking machine and gave me a computer generated printout. Pool store #2 did a drop test and hand wrote the results.
I was prepared to take action to lower the pH and stop using my Trichlor pucks based on the results from #1, but obviously my actions will be different if I trust #2.
Thanks for your thoughts.
Jim
That's good to know ...I've been called a Rat a few times.
