Thread: What is best pump/filter for 300 gallon kiddie pool?
    Jul 2011
    Cool What is best pump/filter for 300 gallon kiddie pool?
    Hello, just purchase round 7X7X1 vinyl kiddie pool. Got the chemicals and the vacuum as well. I'd like to get a affordable pump/filter to help keep this pool healthy. I figure I will be having to drain and refill weekly if I get lucky. Any recommendations would be very much appreciated. Thanks so much, Bev in Camarillo, CA
    Default Re: What is best pump/filter for 300 gallon kiddie pool?
    I assume you mean 7' diameter, 1' deep? That's only about 275 gallons -- there's not really any pump made for such a small pool. You probably would be better off just using spa chemicals and doses, and draining and refilling every 3 - 5 days.
    Or, you could take the money you were planning to spend on the pump and filter, and buy a $350 Intex 15' pool, that comes with a little pump and filter.
    Jul 2011
    Thanks Ben. Yes, it's a 7' round pool. Your advice is well taken. Makes sense. Thank you for taking the time with my post.
  1. Aqualeisure dolfino 6 foot 424 gallon easy set up pool with pump
    By pupplove in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-06-2012, 08:31 PM
  2. Kiddie pool PH help
    By landbk in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-27-2012, 11:42 AM
  3. kiddie pool
    By jnkoh in forum Above-Ground Pool Construction & Repair
    Last Post: 06-30-2011, 08:20 AM
  4. Help with filter selection for in-ground 35,000 gallon pool
    By rshady in forum Pool Equipment & Operations
    Last Post: 06-02-2011, 03:50 PM
  5. Help Size Pump and Filter and Calculating Gallon Capacity of Pool??
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 07-20-2006, 02:45 PM
