Page 2 of 9 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 89
Thread: Brand new pool owner = new to BBB method
    Default Re: Brand new pool owner = new to BBB method
    1. Approximately 2.5ppm
    2. Never add 11 lb. of anything at once. You may either overshoot your target or end up with cloudy water. Add a box of Borax and wait several hours. Then retest pH and redose if needed. Anywhere between 7.2-7.8 is ok. Once your pH starts to move, you might want to go to smaller doses than full boxes at a time. Do NOT test pH when your chlorine is high, however, or you will get a falsely high pH reading. Test pH before adding a new dose of bleach.
    3. I don't know. I haven't bought any CYA lately.
    4. When you can pass the overnight test, I'd keep the chlorine high for one additional day for added insurance and then let the cl drift down and maintain it between 3-6ppm all the time.
    Jul 2011
    just got back from testing the pool at sundown. FC was at 1 ppm. TC was at 3. Ph was at 7. CH was 230 ppm. Ta was 90 ppm. The CYA was something less than 30 but i couldnt tell b/c the tube was full and i could still see the dot although cloudy. The chlorine tests are approximate (and consequently less accurate) bc the colors are hard to distinguish sometimes (see further down in post)
    i added 3 gal 3 quarts as i did earlier to bring it back up and then tested the water a little bit later and got an approximate reading of 10 ppm. Again Im not sure b/c the colors are hard to distinguish and I had to use the dilute method b/c the reading was above 5 ppm.
    Im going to add the CYA tomorrow as you suggested.
    I edited out the borax comment bc i just saw your earlier reply. 10-4 on the borax instructions.
    I also ordered the Taylor K-2006 kit as suggested on here and am going to return the one I got at leslie's...its too freakin' hard to read the color adjustments for chlorine, especially at shock levels or anything above 5 ppm. Unfortunately the kit wont be here until next week
    how we doin' so far? what ya got for me?
    Check the post above yours. I just replied one minute before you posted again. Good decision to get the Taylor K-2006. You won't be sorry. You're doing fine! Keep us posted how things are going.
    Jul 2011
    Thank you so very much for the help! I will most certainly be donating to this site.
    Can the CYA and borax be added at the same time (seems as tho they can be).
    I have another dilemma which I need help with. So within the past week Ive had a ton of stuff going on. Closed on a new home. Been doing some renovation to it. Reading, learning, and applying new info to maintain a pool for the first time On top of all this, Im going on vacation on friday and will be unable to provide the pool with my undivided attention as I am now. At this point, I'm not sure the pool will be out of the shocking stage by early friday morning. That being said, how can I get through the next week without coming back to a swamp. I will not be home but I have family who will be watching the house and pool. They have never had a pool and have no knowledge about pool maintenance.
    What would be the best course of action? put several (if so, how many) 3" trichlor pucks in a floater and leave the pump on all week?
    Its been a whirlwind of excitement and activity with all this going on and im trying to keep my head from spinning off, lol
    How often are the family members going to come and check the pool? Let's see what kind of overnight loss you have for the next couple of nights and also how the water looks by Thursday. Also what kind of chlorine loss you have from one evening to the next. Then, we'll make a recommendation for you. Even if you don't complete go algae free the whole time you are gone, we can help you clean it up when you return.
    EDIT -- It is ok to add CYA and Borax one after the other.
    Last edited by Watermom; 07-05-2011 at 11:47 PM. Reason: forgot to answer part of the questions
  6. #16
    Jul 2011
    Will add the CYA and Borax tomorrow.
    as far as people checking on the pool...one or two family members will be at the house on a daily or every other day basis renovating and can check on the pool.
  7. #17
    It's a plaster pool, so excess chlorine won't hurt anything. 30K pool, so 1 gallon of plain 6% bleach = 2 ppm.
    Do this:
    #1 - Buy 4 gallons of bleach for EVERY day you'll be gone, plus 8 more gallons.
    #2 - Have your family add 4 gallons each day, preferably in the late evening. Don't bother with testing.
    #3 - YOU add 4 gallons each day, the first 2 days you're back, because you probably won't have time to pay attention to the pool.
    #4 - Caution your family that that they need to purchase AND ADD 1/2 gallon for each person who swims each day.
    #5 - Tell them that the chlorine levels may (or may not) be VERY high - if they swim, and add the extra bleach, it will be fine. BUT they should wear old swim suits or swim without them, since the chlorine levels won't hurt people but may hurt the swim suits. (That said, very high chlorine can dry or 'chap' your skin.)
  8. #18
    Jul 2011
    Do this:
    Will do. I'll need to stock up on additional bleach from Walmart. Should the pump be on 24/7 next week?
    Update on today's testing results:
    7am: approx. 1.5 ppm. --> added about 4-5 gallons of bleach (cant remember now bc i forget the piece of paper i wrote the levels/amounts down on and its been a long day of renovating)
    1pm: approx. 10 ppm --> added 1.42 gals (1 walmart sized bottle of bleach)
    3pm: approx. 10 ppm --> added 1.42 gals (1 walmart sized bottle of bleach)
    5pm: approx. 12 - 15 ppm --> added 3 quarts
    Other stuff:
    8am: added one box of borax. tested Ph and it went up to 7.4 from 7.0 -- a second test later in the day also showed 7.4
    2pm: added approx. two pounds of CYA via sock method as suggested and squeezed the sock several times today
    The FC measurements i posted are approximates due to the terrible color matching system of the current kit i have...eagerly awaiting the k-2006 arrival
    also, i have a pool guy coming tomorrow to go over the workings of the plumbing and filter system (a d.e. filter). From the brief reading ive done on these filters, would cleaning it/backwashing (i forget if thats the correct terminology) be harmful to the current shock process?
    Last edited by stslimited84; 07-06-2011 at 08:54 PM. Reason: added additional info
  9. #19
    Quote Originally Posted by stslimited84 View Post
    The only "harm" it would do is to cause you to lose "shocked" water, so if you have to refill to top your water level off again, you'll need to add more bleach to get back up to shock level.
  10. #20
    Jul 2011
    found my note paper with the test results. Here are the results i wrote down today:
    7am: approx. 1.5 ppm. --> added about 4-5 gallons of bleach (neglected to write this amount down)
    1pm: approx. 10 ppm --> 7am: approx. 1.5 ppm. --> added about 4-5 gallons of bleach (cant remember now bc i forget the piece of paper i wrote the levels/amounts down on and its been a long day of renovating)
    1pm: approx. 10 ppm -->added 3 quarts
    5pm: holding steady at 15 ppm
    Tested the water around 845pm tonight and got a reading of 7.5 ppm, but Im skeptical of it b/c of having to use the diluted water method for color matching...it may very well be higher. To be safe I added 3 gals of bleach to bring it up to 15 ppm. Will test again in the morning.
    Should I leave the pump on 24/7 through next week? Anything else I need to be doing at this point?
    Tomorrow Ill be returning that crappy test kit to leslie's and monitoring the pool throughout the day while renovating.
  1. brand new pool owner with brown water and cranky kids !! :(
    By jennifert in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-18-2012, 12:45 PM
  2. Brand New Pool Owner Needs Advice On When Swimming Can Commence!
    By Jeannie in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-23-2011, 12:32 AM
  3. Brand new pool owner and clueless
    By StrikeToWin in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-21-2011, 05:57 PM
  4. Brand New Pool Owner wants to start off on the right foot!
    By StuckiTribe in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2010, 08:29 PM
  5. Brand new pool & SWG owner!! aka NEWBIE!!
    By deca1975 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-12-2008, 08:08 AM
