Hey Guys,
I just stumbled upon this great website about 30 mins ago and have been eagerly reading since. Here's the long and short of it. Recently purchased my first home which came with an in ground plaster pool. The pool is currently filled with water and the owner was having a weekly pool service which stopped about a week ago. Here is the equipment list for the pool along with links for your viewing:
A.O. Smith SQ1102 Square Flange Motor - http://www.aqua-man.com/row_num.asp?Ic=1133
American Products DE 48’ sq Model # 584090
Heyward CL-220 - http://www.amazon.com/Hayward-Off-Line- ... B000NPGHFE
(attached spa) Air Supply Silencer Air Blower part # 6318120F - simliar to this http://www.amerimerc.com/air-blower~silencer.htm
Went to the Leslie's today and bought the following based upon a conservation with a friend who just started maintaining his own pool:
Leslie's 3" chlorine tablets
power powder plus
fresh n clear
DPD Deluxe Test Kit
The pool needed water, and after filling the pool to the skimmer half way point, I tested the water with the above kit and got the following results:
Ph = 8.0
Alkalinity = 110 ppm
Chlorine was 0
Temp = 84 degrees
I stumbled upon this site and quickly realized/learned i wanted to go the BBB route. The only thing Ive done thus far today is added 12 chlorine tablets to the Heyward Cl-220 but even at that point, the pump ran only about 1.5 hours. Tomorrow I want to pick up everything I need to get the pool up and running properly using the BBB method. What do I need to do/buy?
Any and all assistance you guys can provide to this novice will be greatly appreciated! Tomorrow I'll be exchanging the test kit for the complete leslie's kit listed in the guide. I'll also return both shocks if needed. I believe the pool is 30,000 gallons but I'm not positive and need to find out for certain.
Thanks in advance for the help. It'll go along way to reducing the stress of owning our first home and pool!![]()
