Results 1 to 10 of 13
Thread: Can't hold FC
    Default Re: Can't hold FC
    Slight correction: 1 gallon of bleach adds 2ppm to 30,000 gallons, not 2 gallons, which would add 4ppm. Just a typo.
    HOWEVER, as recommended, the 10 gallons adds 20ppm of chlorine to 30,000 gallons and that is EXACTLY how much you need to shock your pool with its high CYA level of 94.
    Jun 2011
    Virginia
    Thanks for the correction. Good progress after two nights of 10 gallons. After the first night, i was able to hold between .65 and 1.3 for 24 hrs.according to my liquid test kit. This morning (8 hrs later) I am testing 10 plus (Taylor Kit not arrived yet).
    Question on the ammonia test. First, I purchased the liquid test kit from Pet Smart. It has a excellent color chart with a white background that allows you to get a true color comparison. My question is should I use the chart for fresh water or salt water.
    I read somewhere that bleach does add salt. If it is freah water, I have gone from .50 to .25. If it is salt water, I am .0
    I feel good about the progress. I am sure my recycle guy will wonder what I am doing with all the bleach.
    Your use of bleach wouldn't be enough to make the water "salt".
    Regarding bleach bottles, I've seem some pictures of them stacked WAY high when folks had to clean up a swamp on a large pool.
    In a few places you can buy fresh industrial bleach (10 - 15%) in 3 - 5 gallon containers.
    For every 10 ppm Free Chlorine (FC) added by ANY source of chlorine, the chlorine when consumed/used will result in 8 ppm salt. For bleach or chlorinating liquid, they add an additional 8 ppm salt upon addition. With 2 ppm FC per day chlorine usage, this means that bleach or chlorinating liquid will add around 100 ppm salt per month if there were no water dilution, so not very much given that salt water chlorine generator pools are 3000 ppm.
    Jun 2011
    Virginia
    I think the FC issue has been resolved. I now have no ammonia. I used 10 gals of 6% bleach two night and 5 gals the third night. 33 hours later I have a FC 8.67 and TC 9.19 and combined .52
    I'm I correct in thinking I need to stay with bleach rather than continue using the Poollife/Calcium Hypocholrite since my Calcium Hardness 475 and my Cyanuric Acid is 68?
    Yeggim is offline Registered+ Thread Analyst Yeggim 0
    Aug 2010
    Philly
    Quote Originally Posted by nepsa View Post
    ...I'm I correct in thinking I need to stay with bleach rather than continue using the Poollife/Calcium Hypocholrite since my Calcium Hardness 475 and my Cyanuric Acid is 68?
    Yes, you are correct. Your thinking is very good and on the right track.
    I imagine it must sound like a broken record sometimes. Bleach, bleach, bleach. But it's the safest thing to add when chlorine is needed. It just adds chlorine, water and a minute amount of salt. Until new posters come back with water test results, liquid chlorine (bleach) is recommended for just that reason.
    Then there's situations like yours. Liquid chlorine then becomes the only chlorine source that should be used. Looks like you done your homework.
    Jun 2011
    Virginia
    Thanks so much for your help. By the way, I went to the pool store to get a test from them. They were clueless to the ammonia issue. When I started to share about the bleach, he tried to change the subject, but I did not let him off the hook.
    Now that I have my problem corrected, I have the time to start reading the very value information your forum provides.
    Until the next time---have a good one!
  1. Chlorine Won't Hold
    By kkresse in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-21-2012, 10:17 PM
  2. Will not hold chlorine
    By VetteGuy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-21-2012, 05:11 PM
  3. Chlorine will not hold
    By wposton84 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2010, 04:34 PM
  4. Cant hold chlorine
    By herrmanncr in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2010, 12:08 PM
