Welcome to the forum.
Do you have normal sidewall returns in addition to the floor popups and a valve to select where the return water goes? Filter size aside, 30-35 psi is probably in the totally blocked range. Whatever you do don't run the pump for more than a few minutes with pressures this high. If the flow is totally blocked you can raise the temperature of the water in the pump high enough to warp the case.
