Thread: chlorine lock?
    Jun 2011
    Default Re: chlorine lock?
    ok, here's where I'm at.
    Added 10 gal 6% bleach on 7/1. Took SWG out of service. Ordered k-2006 from amato and received today. went out to pool to get water sample. Pool walls are greenish. We were away for the weekend so nobody used the pool.
    Took sample about 2 feet below surface to test. I didnt get chance to have leslies retest water so i hope i did it right.
    Did FC and CC at both 10 ml sample and 25 ml sample.
    no pink for FC barely any pink for CC. 1 drop cleared it up
    FC= 0
    CC=0-0.2 ppm @25 ml sample
    PH= 7.8
    TA=110 ppm
    CH=140 PPM
    CYA=<30 no cloudy solution after mixing. saw black dot clearly with sample tube filled to top.
    Funny thing about CYA is the test strip shows ideal level. could Taylor R-0013 be bad?
    I guess thats why i never show any chlorine in pool.
    The saturation index, if it means anything is .1 @ 84 degrees F.
    Got 10 more gallons bleach going in tonight. will put some hardness and some more acid and will retest tomorrow evening and post results. I will also take water to leslies in morning to retest
    So looks like the chlorine lock is false. I think the leslies employee did a ph test thinking it was a CC test.
    Recomondations?
    The CYA test in the K2006 is pretty bomb-proof. The CYA tests on strips are notoriously unreliable.
    You'll need to adjust your PM doses upward to levels that leave you with at least 5 ppm in the early AM, after working overnight, in order to make headway with the algae.
    Also, if you can buy some dichlor, and use it to maintain some chlorine during the day, you'll be raising your CYA at the same time. With a 40K gallon pool, you might want to look at a 50# container of dichlor from Sam's. Here locally, they are $110, which is cheaper than I can buy it wholesale. But do NOT buy the mixed or blended shocks!
    If you do get some, you might want to do something like broadcast 5# of dichlor (about 10 ppm FC on your pool), brush your walls, and then add 12 gallons of bleach just before dark.
  1. Chlorine Lock
    By wellioughta in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-11-2011, 12:07 AM
  2. Chlorine Lock
    By pkhydro in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-29-2011, 10:57 AM
  3. Pool guy says Chlorine Lock?
    By Mwil3 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-28-2010, 10:31 AM
  4. Help!! I don't know who to believe - Chlorine Lock?
    By btozzo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-24-2010, 05:31 AM
  5. Chlorine Lock ????
    By poolrescue30 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-18-2008, 06:12 PM
