Thread: Heater Pilot Won't Stay Lit
    Jun 2011
    Southeast Michigan
    Default Heater Pilot Won't Stay Lit
    I have a Hayward CZ150-1 millivolt pool heater for my 16x32 above ground pool. It's old. Every year it's a chore to light the pilot. I usually will have to hold the button for several minutes. This year it will light while I am pushing in the pilot button, but when I release the button after several minutes it immediately goes out. Could this be due to a bad thermopile?
    Default Re: Heater Pilot Won't Stay Lit
    Millivolt heaters are a total P.I.T.A. to troubleshoot, and are a non-ideal design for use around pools, where corrosion is inevitable.
    If the heater's old, and you can afford it, replace it with a modern electronic heater with a salt-compatible heat exchanger, and a 120V electrical circuit. If you use the heater much, you can afford it, since older heaters tend to degrade in efficiency a LOT due to external heat exchanger corrosion.
    If you need to work on it, use this page:
    http://www.poolsolutions.com/search.html
    and the search phrase "millivolt pool heater"
  1. PH won't go/stay up
    By GAPool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-25-2013, 12:40 PM
  2. Pool heater won't stay lit!
    By Rob311 in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 09:38 PM
  3. Hayward H200 heater pilot will light but unit doesn't get very warm
    By Joe Stephen in forum Pool Equipment & Operations
    Last Post: 06-20-2011, 10:47 AM
  4. Pool Pilot piping and Heater
    By Daggit in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2010, 02:53 AM
  5. pilot light won't light on pool heater
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 03:10 AM
